Just installed the RPM Extreme Fan Controller on my 2021 392. Drove around for about 60 minutes and the highest temperature I saw was 207 degrees. Most of the time it was between 197 and 203 degrees. Engine oil temp has also dropped about 25 degrees. I'm hoping this will also help keep my power steering motor a little cooler. The website has now been updated to include the 392 Jeep Wrangler.
Factory Fan Settings
203* t-stat starts to open
206* t-stat if fully open
226* fan starts to run
235* fan on full
250* limp mode
195 degrees = 15%
199 degrees = 30%
205 degrees = 50%
212 degrees = 75%
218+ degrees = 100%
Jeep JL - JT PWM FAN CONTROLLER
PWM FAN CONTROLER with AC PRESSURE MONITORING for 2018 - 2025 Jeep JL-JLU & JT with a 3.6L, 2.0L, or 6.4L HEMI engine. The module is a standalone option for controling a factory Jeep JL-JT PWM FAN. We curently offer several options of PWM controlers NO INPUTS. This unit is...
www.rpmextreme.com
235* fan on full
250* limp mode
195 degrees = 15%
199 degrees = 30%
205 degrees = 50%
212 degrees = 75%
218+ degrees = 100%
