Side door mounted Rotopax VRs spare tire strapped mount ?
Your pics and opinions
Do you have a link to the side door mount you are considering? I like the RSE idea and I have that in my cart right now. Wondering what the other option is.Side door mounted Rotopax VRs spare tire strapped mount ?
I used this on my last rig, unfortunately will not do it again on my current build. Put marks onto the hardtop and if you need to adjust it, may have issues with bolts being seized up. Happened twice to me and each time I had to purchase new pieces to replace.This option gets solid reviews:
Pak Rax Kit for the Jeep JL (2018-Current)
Sold in sets of Pairs (1 per side) Do you ever go off-roading and wonder if you’ll have enough gas or storage? Pak Rax eliminates this concern! With a maximum of 16 extra gallons of gas or 60 lbs of equipment, you can be the hero on the trails! This means you can gotrailrax.com
Not to mention it cost $500 for a few pieces of stamped steel. They are pretty proud of that thing. At that price It looks like they want it more than I do.I used this on my last rig, unfortunately will not do it again on my current build. Put marks onto the hardtop and if you need to adjust it, may have issues with bolts being seized up. Happened twice to me and each time I had to purchase new pieces to replace.
I have never had an issue with mine and I used PPF where it mounts. That being said, I have never even filled the Rotopax with gas or anything else. I leave the PakRax installed just because I like the looks of it. It makes me look like a secret Overlander.I used this on my last rig, unfortunately will not do it again on my current build. Put marks onto the hardtop and if you need to adjust it, may have issues with bolts being seized up. Happened twice to me and each time I had to purchase new pieces to replace.
This is one that I found . I saw it on a Jeep followed him and asked how he liked it , he said it works well but on wash board roads it can vibrate a bit so he stuffs a small piece of foam between the door and bracketDo you have a link to the side door mount you are considering? I like the RSE idea and I have that in my cart right now. Wondering what the other option is.
That’s another reason I don't use mine.Trying to keep my Rotopax off of the sides as a friend has his torn off on the Rubicon along with his drip rail. Only one shown in this picture, but I carry two.View attachment 43721
It is call a "Waterport". holds 4 gallons of pressurized water. They are all on SeaSucker mounts.What is that black tank above your spare tire?
That's my primary reason for not wanting to go the PakRaks route, even though it's aesthetically my favorite. I'm not convinced that rain guard can handle the weight over time and I expect it to tear off. Especially with 4g, washboards, pot holes, etc. I really like the spare tire solution. An extra 24-36lbs (~6lbs per gal) of fuel shouldn't be an issue on the spare tire with the Mopar reinforced tailgate holding the stock 35" tire and wheel right?That’s another reason I don't use mine.
I've got to better understand these "Seasucker mounts" and how you have the Rotopax and water tank mounted. I looked at the Seasucker website...........so you have both of those mounted directly to the rear glass???? How did you mount the tanks to the Seasucker?It is call a "Waterport". holds 4 gallons of pressurized water. They are all on SeaSucker mounts.
