Rock Slider hole plugs
Mooserat
San Clemente
392, JKU and a Tacoma
I took off the ruby rock sliders and installed some Genright rock rails. I am looking for some plug suggestions the fill the auto body holes you can see, from the removal of the ruby rails.
Do you have a pic to refer to? I believe you're referring to the holes in the pinch seams?
These holes
Some options from my research:
- Vinyl tape
- Hammerhead Armor's 4-Door Jl Bottom Trim
I'll probably just leave the pinch seam there without covering it... mine is already black so...
looks like the hammer heads will tighten it up.
@Mooserat - that was what I thought. Here's an option for you that I used prior to getting my RSE step-sliders.
Hammerhead Bottom Trim Pinch Weld Covers - Link
Edit - looks like @Fast&Furious found the same!
Looks like the Hammerheads are on sale right now (code summer15) bringing the total down to $92. Not bad!
When I removed the stock Rubi Rails to put on my new steps, all the dirt and debris that collected in those rails and all over the pinch seam made me believe leaving the pinch seam exposed is the best long term. My jeep hadn't been exposed to water for over 1 week when I took them off but there was water in the rail and the pinch seams were wet/muddy when I removed them (hadn't been off road either). All that dirt and moisture that accumulates that you cannot get out would cause more rapid rust in my opinion. Thats my $.02
These worked great, thanks! I ordered 2 pair by mistake, the website is confusing.
One more thing I didn't know I needed! Damnit!
