Rigid Adapt xp extreme
MrDavo
Los Angeles, California
2021 Jeep Wrangler 392, 2016 Jeep Wrangler Hard Rock
Has anyone used this on the front bumper instead of the lp6’s
Yes LOVE!!!!
If you have a hook up I want another set of the 90 watt ones
warranty for life
When setting these up, do you use 2 aux switches? Similar to LP6’s, one switch for high and one for low? Thanks.
yes, spoke to them yesterday as it is a little confusing.
they claim the red wire powers the switch. I am referring to the red wire that goes to the switch. Run the white and the blue that also go to the switch one to each aux switch so two total yes.
Alternative is ditch the harness complety and go from the lights wire end black to chassis ground, red to one aux and white to another aux. 10-12 gauge wire, I chose 12 based on the size of existing.
Ended up with an extra set if anyone needs
