Rear Window not working
Rubi392
Connecticut
Hello,
2021 392 with 27 miles. Decided to take top off for summer and realized my drivers side window does not go up or down from either front or rear window switch. Have tried the window lock switch and also unplugged door and plugged back in few times. Anyone else have a window that didn’t work?
Thank you
Make sure the wires are seated into the backs of both plugs. Even if they look it, just firmly push them all in
Reactions: dog
Might be able to either check wires with voltmeter or carefully maneuver door to other side and support it somehow and hook it up to passenger connector and see if it works.
Motor probably has a resistance spec or you could compare it to other side.
Surely they all operate off same fuse.
