Rear bumper
Earl 392
Tucson AZ
Earl 2023 Jlu 392
Who’s running next venture rear bumper featherweight or rim rocker. One says 6 mounting locations and one says 8 mounting locations. Both keep stock hitch. Tell me more.thanks
I’m running the featherweight. 8 mounting points. 3 horizontally into the frame rails on each side and 1 on each side from the bottom. Had to use a chainsaw file to tune a couple holes and it fit perfectly. Still fighting getting the back up sensors set in the right spot, common problem with aftermarket bumpers. I used a short 22mm O2 sensor socket for the bottom horizontal frame bolts, made it easy to get the bolts tight. Otherwise they are hard to get on. Love the quality and fit overall. And it is nice and light.
Looks nice did you paint it or powder coat it it looks like flat black
