Rear Bump stop replacement.
Minjin
Ohio
2022 Wrangler 392
Replacing my lift, I noticed that the bump stops were trashed. Anyone have a recommendation for a good replacement other than stock?
Or go big… 💸 🤙🤑
In all seriousness, you’re bottoming out too much and you should build-in some more down travel/compression strength. Slamming your bumps is a good way to break a axle!
Stiffer springs would be the best place to start if you’re on a budget.
Or go big… 💸 🤙🤑View attachment 45843View attachment 45844
I have King coilovers and bump stops on the way from Rebel Off-road 👍
