PSC Steering Available Soon
RKKRAWL
High Desert
2021 Rubicon 392
Talked to PSC today and they said 392 kit should be available late this month, way ahead of schedule. New pump, reservoir, steering box, ram and hoses, cost will be around $3800
I spent a ton on a psc setup on my 16 JK - hated it. Never again.
i had the redneck ram on my jk and liked it. No new pump. Just send gearbox in to get tapped and fitted with hydraulic lines. Not sure how it works with our electric pumps
They were saying a couple of more months, if your in a hurry Redneck Ram re-drills your stock box the same as PSC and can supply you with hoses and a ram. They re-use the stock electric pump.
A local shop drilled and tapped my box and I added a PSC ram on the factory pump. I at running 40” tires and it works great. One downside is the steering is a little slow.
I have not added the apex kit but you can also bump the factory pump a little by adjusting the factory set screw the apex kit replaces. I plan on trying this but haven’t got to it yet.
