Power Steps
Little Buckaroo
New member
LA
2004 TJ with LS3, and 2016 Rubicon Unlimited
I need a measurement for a power step. what is the length from the bottom of the door to the ground with 33" & 35" tires.
From the ground to the bottom of the door.
steps= Best top, AMP & ARIES ACTIONTRAC POWERED RUNNING BOARDS
I Want to find the one that put the step halfway
I can't give you an accurate measurement, because I've already lifted my Jeep and have 37's on it. However, one other powered step to consider is the Rock Slide Engineering Step Slider's. I installed them on my Jeep and the step drops down to a perfect height for me. The step drops down approximately half way for my application.
RSE are awesome I have them on as well.
I noticed some issues up in Yankee states with their weather but down south in warmer climates I’ve never had an issue. To correct any issues (step getting stuck down) I just reset the fuse. I WD40 them once a month.
I have a stock 2022 392 (non-XR) with 33" tiress.
From the ground to the inside front doorsill is 26".
From the ground to the step of my Amp Research Powerstep XL steps is 13", exactly halfway up, which is perfect for my 5'2' wife!
Reactions: dog
I have a 2.5 inch RockKrawler lift on 37s with RSE steps…. Right at 30inches to top of door sill. The step is 15inches when down
Does this look the right amount of drop for Amp Research XL (77132-01A) steps on 2023 XR?
I thought step would drop lower?
I didn't install the steps, do they have adjustable drop length?
Ad says stepping surface is 13" down measured from sill plate.
LOWEST DEPLOYED STEP
PowerStep XL Running Boards drop 4" lower than the other PowerStep boards, making them perfect for lifted trucks or vehicles with higher ground clearance. Also, most stationary running boards rest 1-2 inches below the body and are often too far from the ground for many passengers.
