'THIS IS MY JEEP WRANGLER RUBICON 392. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE....' Credit - FMJ 1987
When I started spec'ing out this build some time ago, I had only a few goals in mind: 1) Keep as much of the OEM Jeep 392 aesthetic as possible as I just like the fundamental look and 2) build a rig that I could comfortably travel to virtually any moderate/difficult trail, not have to worry about performance, and have the confidence that she would hold up. That said, it was my first trip to Moab that changed my perspective... As I've never done a build thread, what started out (as many of us do) as a lift kit, shocks, and tires has morphed into something I couldn't be more happy with.
There are many member builds that I've taken some inspiration from as let's be honest, this group has some absolutely phenomenal builds! I find this build to be neither over-the-top nor flashy by any means, but it certainly fits my wants & needs (and budget) and has a clean look. Special shout out to @prodriquez @ParadigmDawg and @jeepguru for the insight along the way. And mostly importantly, Cody and the guys down at Advanced Mechanical Performance who basically started over and did the install.
Dynatrac Elite ProRock XD60/80 – 72.5” – 4.88 – Auburn ECTED MAX Lockers
Dynatrac HD Steering Kit
Dynatrac Tie Rod – 1.5”
Steer Smarts Yeti XD Drag Link
Adams JL Front 1350 CV Driveshaft – Extreme Duty Series
Adams JL Rear 1350/1410 CV Driveshaft – Extreme Duty Series
TeraFlex Alpine RT3 3.5” Short Arm Suspension System
Clayton 3.5” Coil Springs - Front
Clayton 3.5” HD Dual Rate Rear Coil Springs
TeraFlex HD Forged Adjustable Track Bars (Front & Rear)
TeraFlex Alpine IR Short Control Arms (All)
Falcon SP2 3.3 Fast Adjust Piggyback Shocks – EcoDiesel/4xe/392
TeraFlex SpeedBump & Progressive Bump Stop Kit
RockJock JT (Heavy JL) Antirock Front Sway Bar Kit - .850 Bar
RockJock JL Antirock Rear Sway bar Kit - .850 Bar
PSC Cylinder Assist Steering Kit – 392 HEMI – 6.75” Stroke – 1.5” Tie Rod
Nitto 40x13.5R17 Trail Grappler Tires
TeraFlex Alpha HD Hinged Spare Tire Carrier
TeraFlex HD Mount Kit 8x6.5
Battle Born Sierra Flow Formed Beadlock Wheels – 17x9 – 8x6.5 – 5” BS
Gorilla Open End Lug Nuts - Chrome
APEX RPV Std Length
AAL High Line Fender Brace w/Daytime Running Lights – Clear
AAL Fender Retention Kit
WARN ZEON 12-S Winch
WARN Winch Mounting Plate
Rock Slide Engineering Step Sliders
Rock Slide Engineering Step Slider Skid Plates
Artec 392 Full Belly Pan
Artec 392 Exhaust Skid
Artec Rear Inner Fenders
Artec Front Inner Fenders – Falcon Shocks
Artec JL Rear Axle LCA Bolt-on Skids
Mopar Grill & Winch Guard Hoop
Mopar 7” Off-Road LED Light Kit (Mounted on Guard Hoop)
Mopar 5” Off-Road LED Light Kit (Mounted on Cowl)
KC HiLiTES Ditch Light Mounts
S&B Cold Air Intake – Jeep Wrangler 392 – Cotton Cleanable
Wildwood Steel Braided Front Brake Line Kit
TeraFlex Steel Braided Rear Brake Line Kit
Redline Tuning QuickLIFT Elite – Jeep Wrangler Rubicon 392 Hood
67 Designs Series 55 Rail Mount System
RONIN Jeep SMARTLOCK Flexible Antenna 12in
Hotheads Headliner System w/ Sound Assassin
Weathertech Floor Mats – Front, Back, & Cargo
Spiderwebshade JL4D 2pc
GPCA GP Grip Pro 4+2+2
Z-Automotive Tazer JL Mini
Z-Automotive Locker Controllers – Aftermarket Axles
Gorilla Glass Windshield
Optima Yellowtop DH7 Battery
Seriously considering the SquadBox for when the top comes off.
I've got about 200mi left on the break-in, then we'll flex her out to get all of the bumps set correctly. I know with the 72.5" Axles and by retaining the factory fenders & fender trim I'm not going to be setting any flex records, but I'm good with that until something breaks; which it will. Atlas in the future.... well, maybe.
Cheers All
APEX RPV Std Length
Cheers All
