My passive entry isn’t working anymore. Any ideas what I can do? I change the batteries in the key fob and under settings on radio passive entry is check marked to on. So I don’t know what else it could be. Seems like fuses are all good
Make sure all the wires are seated well at the harnesses in the footwell.The sensor for the Passive Entry is integrated in both the driver and passenger front door handles. There is a power wire running to those two handles that could have an issue. Have you tried both the driver side and passenger side doors? If that doesn't work on either side then it's probably not the door handle sensor and might be the key fob itself. I know you replaced the battery in your primary key FOB. Have you tried the other key FOB with a new battery? You already checked the fuses, but have you taken the doors off? If so just make sure the door wire harness is fully connected. If it is more complex I'd probably just take it to the dealer and let them chase that little electrical gremlin around for a while.
Good Luck!![]()
i noticed this as well. Always forget my phone is with the key.One thing I have found with most proximity sensors for entering the vehicle is if the fob is in my pocket with my cell phone the sensors do not work. I need to have the fob and cell phone in opposite pockets.
My passenger side will unlock when I’m standing on the driver side.Another thing is FOB distance from the door handle. I noticed on the passenger side I have to have the FOB closer to the handle to make it work. Try holding it right up to the handle if you haven't tried that yet.
