Oem 392 front bumper with factory winch
great one 99
New Hampshire
ford raptor
I destroyed my front oem bumper , I have the factory winch , if I order thru dealer can I order the full bumper with fogs and bezels , or will I need to do some swaping with my old bumper .
You should be able to order any part you want through your dealer.
According to my dealer, you can’t order a pre assembled bumper. You just have to order whatever parts you need. My old bumper had a few good parts on it when i replaced it
Look around, you can find OEM takeoffs pretty cheap. Or this is a great time to upgrade to a better aftermarket bumper.
I have been they’re not easy to come by . I have the factory winch, the dealers trying to tell me it’s one piece with the winch meaning you have to remove the winch as well. I thought the winch sat in a cradle , when you could take the bumper off independent of that. meaning you shouldn’t have to mess with the winch if you were just replacing the bumper.
I'm pretty sure you have to remove the winch as well, you'd take that off in the process of removing the bumper.
Not sure if you're bound by a certain price, but there are plenty of results on Mopar's site searching "Front Bumper", from complete sets to just the beam, etc.
We added a winch to our 2023 and it all bolts together. If memory serves me correctly we bolted them together and put it on as one piece. That being said you can most certainly separate them. Good luck.
That’s how mine went on. Winch bolts onto winch plate then the bumper slides over and bolts on the frame after.
