Hi all,
Has anyone installed the NVM fenders yet?
I'm reconsidering splitting my factory fenders with Quaker leds and getting these instead to fit the lift and 38s I'm currently planning.
Curious how you like them from an anesthetic and functional perspective plus if ypu ordered them powdercoated or had it done locally.
Thanks!
JL/JT Aluminum High Line Fender Flares (Front)
Introducing the first real functional high line fender flare option for the JL Wrangler and JT Gladiator! These flares increase tire clearance over split/modified Rubicon factory flares and actually sit a touch higher as well. 3/16" Aluminum Laser Cut, CNC Formed, TIG Welded Construction 3/16"...
nextventuremotorsports.com
JL Aluminum High Line Fender Flares (Rear)
Introducing our aluminum high line fender flare option for the rear of the JL Wrangler! These flares increase tire clearance over split/modified Rubicon factory flares and actually sit a touch higher as well. These are designed for a slight rear wheelbase stretch (not required) and room to...
Thanks!
