I am currently in Moab and have encountered a problem, well challenge, with the No Limitz.
I made the drive from Pensacola, Florida to Gallup, New Mexico, 1,430 miles, and 99% of this portion of the Moab trip was interstate. I left the No Limitz off and the MDS performed as normal.
I left the interstate and traveled from Gallup, to Kayenta, AZ to Moab, another 326 miles. This portion of the trip, I turned the No Limitz on and the MDS never activated. I loved it and the V8 ran in a manner that I expected a V8 to run.
Here lies the problem.
I started riding trails in Moab and the Jeep did not perform very well off road. 4H (4H Part Time) took a lot of effort and did not seem to work very well. The Jeep was sluggish and just didn't respond to throttle input much at all. It felt as if I was pulling a 3,000 pound trailer. It sucked to say the least.
I shifted to 4L and the Jeep performed well, but was unpredictable. Well, is not a good description, just OK, is better. Sometimes, a lot of throttle was required and sometimes no so much. The same thing occurred with engine braking in both 4H and 4L. It was just really strange.
The main problem was the Select Speed Control (the off road cruise control) would not function at all. Well, it sort of did. It would only function as a downhill descent control and would not function AT ALL in any manner that required a forward motion that wasn't led by gravity.
This has something to do with the adjustment in the torque management within the No Limitz.
I turned off the No Limitz so the MDS would function, and the Jeep performed amazing off road, including the Select Speed Control. The way I expected.
I understand that MDS does not activate in 4WD, but if you activate the No Limitz, you must turn it off when you use 4H or 4L, or you will encounter some problems.
On another thought, if you have a Tazer and you turn force RWD "on" so your Jeep is only operating in 2WD and you shift to 4H or 4L, you will still not have 4 wheel drive. When force RWD is on, no matter what position your transfer case is in, including your front locker, your front axle is not recognized by the Jeep and nothing happens.
You simply can't turn the Force RWD "off" and then everything will be recognized. You must shift back into 4Auto, and then shift the transmission to either park or neutral and then turn off the force RWD. All of the 4 wheel drive system will now work properly.
I know this because this happened to me on the side of a hill on Fins and Things, north. Kenny's Climb.
