New Jeep Hurricane Twin-turbo I-6 Engine Announced
Stellantis today revealed its new, 3.0-liter twin-turbo inline six-cylinder engine, named Hurricane, that delivers better fuel economy and fewer emissions than larger engines while at the same time generates more horsepower and torque than many competitors’ naturally aspirated V-8 and boosted six-cylinder powerplants.
Designed with an inherently smooth-running I-6 configuration and state-of-the-art technology, the Hurricane twin-turbo’s robust base architecture enables Stellantis Propulsion Systems engineers to create two distinct variants:
  • Standard Output (SO): Optimized for fuel economy, including the use of cooled exhaust gas circulation (EGR), while delivering enhanced power and torque (more than 400 hp/450 lb.-ft. of torque)
  • High Output (HO): Optimized for great performance (more than 500 hp/475 lb.-ft.) while maintaining significant fuel economy during heavy use such as towing.
The Hurricane twin-turbo achieves this V-8-rivaling performance while being up to 15% more efficient than larger engines.
“As Stellantis aims to become the U.S. leader in electrification, with a 50-percent battery electric vehicle (BEV) sales mix by 2030, internal combustion engines will play a key role in our portfolio for years to come and we owe it to our customers and the environment to provide the cleanest, most-efficient propulsion possible,” said Micky Bly, Stellantis Head of Propulsion Systems. “The Hurricane twin-turbo is a no-compromise engine that delivers better fuel economy and an important reduction in greenhouse gases without asking our customers to give up performance.”
Reducing greenhouse gas emissions is one part of Stellantis’ commitment to cut its carbon footprint by 50% by 2030 and to lead the transportation industry by achieving Net Carbon Zero by 2038. Those goals are key elements of the Stellantis Dare Forward 2030 strategic plan.
The Hurricane twin-turbo flexes its muscle with a broad, flat torque band that sees the engine maintain at least 90 percent of peak torque from 2,350 rpm all the way to its red line.
Specific horsepower and torque ratings will vary based on vehicle. The first vehicles powered by the Hurricane twin-turbo I-6 reach dealership showrooms this year.
The foundation of the Hurricane twin-turbo is a deep-skirt cast-aluminum block with a structural aluminum alloy oil pan. Cross-bolted steel main bearing caps contain the strong rotating assembly of a forged steel crankshaft and forged steel connecting rods. During manufacturing the block is deck-plate honed to optimize the cylinder bore shape, which helps improve fuel efficiency.
Stellantis Propulsion System engineers employed a suite of state-of-the-art technologies for the Hurricane twin-turbo to deliver reduced emissions and attain big-engine power:
  • Two low-inertia, high-flow turbochargers, each feeding three cylinders, for rapid response to throttle inputs
  • Plasma Transfer Wire Arc (PTWA) coating in the cylinder bores for an ultra-thin, low-friction wear surface
  • High-pressure (5,075 psi/350 bar) direct fuel injection with pumps (single for SO/dual for HO) actuated by a dedicated chain-driven shaft
  • Dual overhead camshafts with wide-range, fully independent variable valve timing
  • Fuel-saving engine start-stop (ESS) function with robust starter motor for quick restarts
  • Engine-mounted water-to-air charge cooler with a dedicated cooling circuit (single inlet for SO/dual inlet for HO)
  • Dual water-cooled exhaust manifolds integrated in the cylinder head
  • Continuously variable displacement oil pump with integrated scavenge stage tailors pump output to engine demand, reducing frictional losses and helping save fuel
  • High-flow ball-valve thermostat minimizes restriction in the cooling system, reducing mechanical losses
The Incredible Power of Air
Each turbocharger in the Hurricane twin-turbo I-6 feeds three cylinders. From a performance standpoint, two smaller turbochargers with less inertia spin up faster and deliver boost to the engine at lower rpm than a single, large turbo.
The compressed air passes through an engine-mounted water-to-air charge air cooler to reduce its temperature before entering the intake manifold. Cooler air is denser, enabling better performance via advanced ignition timing, and helping manage in-cylinder temperatures. An electric pump circulates coolant after the engine is shut down to help cool the turbocharger units for enhanced durability.
The high-pressure direct fuel injection system runs at 5,075 psi (350 bar) and uses injectors mounted centrally in the cylinder head combustion chamber. This design promotes finer atomization and super-fine control of fuel delivery into the cylinder for the optimum air/fuel mixture, enhanced by the turbocharged intake air, for higher power and lower emissions.
The Hurricane’s turbochargers are optimized for each version. The turbos on the Hurricane SO deliver peak boost of 22 psi, while the Hurricane HO turbos deliver 26 psi of peak boost.
Helping the Hurricane HO deliver its enhanced performance are lightweight, oil-jet cooled, forged aluminum pistons with an anodized top ring land and a diamond-like coating (DLC) on the pins to minimize friction. The Hurricane HO runs with a 9.5:1 compression ratio and uses 91 octane premium fuel.
With a focus on fuel economy, the Hurricane SO uses cast aluminum pistons with cast iron top ring land insert, running with a 10.4:1 compression ratio. It’s use of cooled EGR helps reduce engine pumping losses and manage in-cylinder temperatures. Premium fuel is recommended.
Tough Coating for The Cylinders
Less friction, reduced weight and unparalleled wear resistance from a thermal sprayed microstructure of metallic and oxide components that metallurgically transformare the key benefits of the PTWA coating inside the cylinders, an alternative to the traditional cast-in-place or pressed-in cast iron cylinder liners. The PTWA coating is ultra-thin, compared with 3 to 4 millimeters of a cast iron liner, and has 10 times the wear resistance.
Minimizing friction throughout the engine enhances its efficiency, reducing its emissions and fuel consumption.
The PTWA coating is applied to the Hurricane block during the manufacturing process at the Saltillo North Engine Plant. The process, adapted from the aerospace industry, melts a steel alloy wire at 2,300 degrees Celsius (4,150 degrees Fahrenheit), producing microscopic particles sprayed onto the cylinder walls at high velocities, where the particles splat-cool to form the coating and form a physical bond to the aluminum cylinder bore. Honing the surface gives it a super-fine cross hatch pattern with controlled micro porosity for oil retention.
The PTWA spray process leaves more aluminum between the cylinders for better heat transfer and engine cooling. This enables propulsion engineers to optimize the air-fuel mixture and advance the ignition timing (spark) over a wide operating range, another mechanism to reduce carbon dioxide and other emissions.
New Member of the Stellantis Propulsion System Family
The 3.0-liter Hurricane twin-turbo I-6 shares design features, including bore and stroke and cylinder spacing, with the globally produced turbocharged 2.0-liter I-4. In North America the 2.0-liter engine is currently available in the Jeep® Wrangler, Wrangler 4xe, Cherokee and just-launched Grand Cherokee 4xe.
The Hurricane twin-turbo I-6 is the primary internal combustion powerplant of the future in North America for vehicles using the STLA Large and STLA Frame platforms. The 3.0-liter Hurricane twin-turbo I-6 is produced at Stellantis’ Saltillo North Engine Plant in Mexico.
Having owned and driven many turbo vehicles, they are just not my thing. The best turbo vehicle I have owned was a BMW M550i AWD with a V8 and twin turbos. The turbo lag was _almost_ non-existent… everything else (Ford, MB, most BMW, Porsche, etc) is not my favorite. The turbo lag is just annoying for a daily driver.
Now the supercharged MB S55 that I had was an amazing treat… especially when temps were down around 20F.
Yes, turbo’s are cheaper to make, get better mpg and are pretty trouble free… but so are Smart cars. LOL
So the MAJOR question is: "Will there be a 2023 Wrangler 392?" I'm guessing the Wrangler Hurricane replaces the 392. Especially because Ford announced the bronco raptor won't be getting a v8.
I'm thinking 2023 could be the last year of the 392, similar to the RAM TRX. I hope I'm wrong!
I think '23 is last year as well. They've already released some teaser shots of the 20th anniversary concept clearly showing a 392 on the hood.
No way that engine will be as long term reliable as a na v8. 26psi boost is a lot. I know they’ve done a lot to minimize turbo lag but still off idle and at very low rpm’s they are just not there. Lugging around at 1500rpm setting off seismographs they will not.
It’s cool and I love technology but the 392 has so much character.
a wider body, better info screen, etc,etc,etc.....Hogs n Hefers!
