JLK392
Looking for some advice on how to straighten the muffler. I know some people have been able to do it.
Are you referring to leveling out the tips?Looking for some advice on how to straighten the muffler. I know some people have been able to do it.
We tried that today. It appears those clamps only go around the exhaust pipes and have nothing to do with the height of the muffler. Loosening them, lifting the muffler, and then tightening them did nothing. I must be doing something wrong.13mm deep socket, loosen the clamp for the muffler hanger, push the muffler up as far as it will go, tighten the clamp, release the muffler, adjust the tips. When you push it up while loosened it will be overcorrected but come back back to about level when you let go of it after tightening.
I misunderstood you saying the muffler was crooked, the clamps allow you to adjust the exhaust pipe location.We tried that today. It appears those clamps only go around the exhaust pipes and have nothing to do with the height of the muffler. Loosening them, lifting the muffler, and then tightening them did nothing. I must be doing something wrong.
There are clamps for each of the 4 tips and you are correct, those only adjust the angle of the tips. If you look to the other side of the muffler (towards front of jeep) you will find two more clamps. Sorry earlier I said there was just one. Those are the ones to loosen so that you can adjust the angle of the muffler. After the muffler is adjusted, adjust the tips so they are even.We tried that today. It appears those clamps only go around the exhaust pipes and have nothing to do with the height of the muffler. Loosening them, lifting the muffler, and then tightening them did nothing. I must be doing something wrong.
Very helpful. I’ll try that this week. Thanks!There are clamps for each of the 4 tips and you are correct, those only adjust the angle of the tips. If you look to the other side of the muffler (towards front of jeep) you will find two more clamps. Sorry earlier I said there was just one. Those are the ones to loosen so that you can adjust the angle of the muffler. After the muffler is adjusted, adjust the tips so they are even.
