Wryfox
Tried searching this topic here many ways but come up with nothing.
Is there more power with the exhaust bypass on?
No.Tried searching this topic here many ways but come up with nothing.
Thanks, didn't know the valve opened under full power automatically. I've never run it in closed modeI wouldn't think there would be a power difference when stomping on it since all it does is block the vacuum signal that is coming from the engine and that vacuum signal goes away when you are on the gas hard. So, the exhaust would be open no matter if you had the switch off or on when stomping it so no difference there. Just normal driving where the exhaust is closed when the switch is off, could theoretically be different power. But, I would think it wouldn't be much difference.
Im thinking it was done on purpose with the vacuum so it would always be open at full throttle.Interesting, so if you don't care about the extra power (if there actually is any) and all you want is quiet tie wrap the valve closed, this way the exhaust note and noise never changes. I might just have to try this. So this brings another question, does this opening happen because of vacuum loss at full throttle? If so, maybe Jeep should have used and electric actuator instead of vacuum. lol
My theory is that it does, vacuum always drops under hard acceleration. This is also why during initial startup the exhaust is always louder until the vacuum builds and closes the valves.So this brings another question, does this opening happen because of vacuum loss at full throttle? If so, maybe Jeep should have used and electric actuator instead of vacuum. lol
No, the valves open under hard acceleration.Tried searching this topic here many ways but come up with nothing.
I would absolutely love to see dyno results for both HP and torque, sometimes reducing back pressure also reduces torque.Yes, it adds 20 HP. Anyone stating otherwise probably has a duck on their dash.
As they say, your results may vary. FWIW, I have one duck on my dash and it's from a niece, so it's staying.I would absolutely love to see dyno results for both HP and torque, sometimes reducing back pressure also reduces torque.
I won't hold my breath on the results though, lol
No ducks on my dash, my 2018 JLUR use to get lots of ducks, my 392 is nearly identical including the color but the 392 gets none. Maybe the 392 is eating them when im not watching. haha
And it adds 1 mpg to the fuel economy.Yes, it adds 20 HP. Anyone stating otherwise probably has a duck on their dash.
Technically at anything less than WOT (and during the delay on opening the valves after you peg WOT) the closed valves will add some amount of back pressure. that added back pressure should affect power and mileage a tiny bit.I haven’t seen any measurable gains with the bypass open. It definitely feels quicker because of the sound, but on the 392 the valves are really there for tone more than power. At wide open throttle they’re open anyway, so the ECU isn’t holding anything back. If there’s any difference, it’s tiny and mostly just the louder exhaust tricking your brain
