BrentField
5 LBS of Boost
I got it ordered. Let's see how it preforms.
Looking forward to seeing the results! Are you doing anything to the internals? Or leaving stock?5 LBS of Boost
You should be ok up to 40k miles (ie: do it before then) with minimal boost.I saw Whipple has one out too now. I'd like to have one installed on mine, but really concerned about reliability. I keep reading that the 392 Hemi doesn't take well to supercharging.
From preform to deform...5 LBS of Boost
I ran my 3.6 boosted to 6+ pro for about 10 years... I had issues with the tuning, but not the mechanical of the engine. Unless you count the time it injected water and hydrolocked it to death. Which was partially the superchargers fault.You should be ok up to 40k miles (ie: do it before then) with minimal boost.
The 392 motor does not have forged pistons or piston ring gaps to support “hellcat boost”. 5 psi or lower seems to be ok based on what a lot of scat pack guys have said.
Lot of people talk against it because of the cost “into hellcat territory” but this isn’t a hellcat nor is there one, so I’m looking forward to seeing what the OP says. Tons of gladiator guys supercharged their 3.6 v6 and seemingly didn’t have issues for an engine absolutely not designed for boost, just an example.
Rubitrux also do Hellcat swaps and no they’re not anywhere close to $10k-$15kIm interested in this as well. But, whats going to make the difference with it is the tune. In my prior experience with bolt on forced induction kits, the tune it comes with aren't that great. Finding a tuner or enthusiast that knows the platform will make all the difference.
These guys are an example:
They even mention they settled at 4.5 PSI of boost in the description.
I don't want to hi jack this thread. But I keep hearing mentions of "just get a hellcat". Knowing this kit runs you 10k and install, with tune, etc will prob run somewhere 15k all in. How much does it cost to get a hellcat dropped in with a 392 core trade and who even does it besides AMW?
Magnuson said the internals are fine with 5 LBS of boost. They actually warrenty it for 36,000 Miles. So that is damn goodLooking forward to seeing the results! Are you doing anything to the internals? Or leaving stock?
They warranty the blower or the motor?Magnuson said the internals are fine with 5 LBS of boost. They actually warrenty it for 36,000 Miles. So that is damn good
There’s some fine print attached. It’s a “limited” warrantyThey are saying if you go over 5 LBS of boost they internals need to be upgraded.
