I finally got around to installing my LP6 takeoffs from my Gladiator. I had previously tapped the the headlight wiring for the backlighting, but wanted to try another approach on the 392. I want my LP6 backlight to come on with the daytime running lights or any time the headlights are on.
I've run the wiring to the first Aux switch wire for the main lamps, but I wanted to avoid tapping headlight or running lights for the backlight. Does anyone know of a fuse location I can piggyback that supports .3 A? If not, I'l just tap the lighting.
Thanks!
Mike
Backlight Wattage (W) | 4.14 |
Backlight Amperage Rating (A) | 0.3 |
Thanks!
Mike
