Ted392
So on the TRX forum, I learned that a simple kill switch could be added without cutting into the factory harness and still retain remote start, so added it to my TRX. I then took apart my 392 dash to expose the start stop button, and I found it has the same wire pattern. So I made one for the 393. Hiding the switch is up to you as to where to locate it.
The picture shows the harness I bought and you only use 2 connectors and some of the wire for the remote switch. I used a quality SPST switch. Took about 1 hour to modify and install. Pulling the dash is easy (YouTube it).
The red wires are the wires to connect to the switch. The green stripe wire and the red stripe wire get soldered together.
I used the grey wires from the kit to extend the red wires to the kill switch.
I used TESA tape to wrap it up. Including the connectors. This tape sucks to take apart.
Cost is about $70. Cheaper if you source the connectors and pins.
Here is the TRX setup.
