Intro
Lucy
New member
SC
2024 Final Edition
Hi, I’m new to the forum. Usually I don’t post things but I am curious what other 392 owners think about the build I’m doing.
Item​
ARTEC Industries Full Bellypan - Aluminum
Front Dana 44 M210 Differential Cover - ARB
Rear Differential Cover
Full Skid Plate Set (engine & transfer case)
RSE Step Sliders (Driver side shown; set assumed)
Rock Krawler Full Suspension Kit (lift + links)
Heavy Duty Control Arms (rear/adjustable)
Steering Stabilizer (single)
Dual Steering Stabilizer Kit
Tires - 35in All-Terrain (set of 4)
Wheels - 17in Beadlock-style (set of 4)
Upgraded Driveshaft (rear)
Performance Exhaust System
Cold Air Intake
Engine Tuning (ECU tune/prog)
Winch (10k lb)
Front Steel Bumper with Winch Mount
Pedal Upgrade / Covers
Rock Rails / Rock Sliders (full set)
Hardware & Alignment Kit (fasteners, shims)
Add another wheel and tire so you have a set of 5… so you have a matching spare
What are you planning on doing with your jeep? Design your build around that 😉
Short answer to what you posted:
  1. If you’re committed to a 35” tire, don’t upgrade any suspension, drivetrain, or steering components. The stock suspension will handle everything and you’ll save yourself around $7,000+ bucks.
Longer simple answer:
  1. A lift allows you to run bigger tires.
  2. Bigger tires give you more ground clearance.
  3. More ground clearance = more off-road fun.
  4. If you’re going to take your Jeep off-road… move to a 37” MT tire (I like Cooper or Nitto). The sidewall of an MT is superior in every way.
  5. If you’re running beadlocks… see #4
Lastly, I would skip the steering stabilizer upgrade unless your flat-towing behind an RV or its worn out. I have the full PSC kit on one of my 392’s and I moved my adjustable Teraflex stabilizer to my wife’s 392 when I upgraded. The stock one is more than sufficient.
