Installing NoLimitz on 2024+ 392s
RickinAZ
Phoenix, AZ
2026 MOAB (12th Jeep)
Thanks to members @OldVetteGuy and @Winston for helping me on my install. I've attached a note that I sent to Z Automotive. After reading it, you'll be able to complete your installation. Steps #2 and #3 of the installation addendum for the 2024+ are flat out wrong:
Z Automotive,
I love your Tazer, which is why I purchased a NoLimitz for my new 2026 MOAB 392. Unfortunately, I had to return it after getting stuck following the written installation guide's addendum for 2024+ Wranglers (https://cdn.shopify.com/s/files/1/0664/6857/7446/files/NoLimitzJLInstallationGuide.pdf).
In Step 2, the guide instructs the installer to “pry the panel up a bit further and remove the two screws below and to the right of the AC vent (C).” Instead, it should direct the installer to remove the dashboard end cap rather than continue prying on the panel from Steps A/B.
In Step 3, it says, “Pry a bit more and lift up the narrow bar section of the panel, revealing three screws beneath (D).” It would be much clearer to direct the user to locate the hidden tab covering those three screws.
Your YouTube installation video is excellent. A 392 forum member shared it with me, and after watching it, I reordered the NoLimitz and am now confident I can complete the installation. Unfortunately, your website links to the poorly worded written instructions rather than the video.
Updating the written guide and prominently linking the video would likely help reduce confusion—and your return rate.
Rick
Great video. Thanks for the link. I’ll be using a small ratchet instead of a stubby screwdriver, tho.
Good plan. I couldn't reach the rearmost screw in C even with the stubby. I used a 7mm wrench instead. .
