Fox ATS plus Steer Smart bracket. I have a RK lift on 38s, 90 mph on cruise control is no problem,
Are those Clayton coils noticeably stiffer or harsher around town?I added a Fox ATS steering stabilizer, Clayton 392 coils and the slightly longer Mopar lower control arms. This firmed up the handling for not much $.
Noticeably firmer but not harsh. I put on the Clayton coils because I installed a Metal Cloak winch plate and a Warn winch so I was worried about front end sag with the stock coils. The Jeep still rides great!Are those Clayton coils noticeably stiffer or harsher around town?
Handling and steering while obviously related are not the same. Replacing steering components as has been noted is the way to go. The ultimate is hydro-assist, but it’s expensive and still relies on all the other parts being right, tight, and aligned with caster around 6Mine is an all factory setup. The handling, especially at highway speeds can be a challenge. It is very loose and can drift a lot. I really don't go off-road. Looking for recommendations and best bang for the buck.
The 392 drifts more than other Jeeps I have run so I haven't checked the caster angle but if you are saying that longer lowers helped then you may have answered my question. Pushing the angle back a little probably helped a lot. A little toe in over spec on the tires helps as well. I always did a 1/8" to 1/4" with no affect on wear.I added a Fox ATS steering stabilizer, Clayton 392 coils and the slightly longer Mopar lower control arms. This firmed up the handling for not much $.
I just had the dealer do an alignment and it both wheels were out in the same direction by more than 1/4", thus the pull to the right.
The sway bar won't affect wander but it's definitely noticeable in handling turns. If you ever want the best of both worlds for on and off-road, I highly recommend ORO Sway-Locs. Back when I ran sway bars on my TJ instead of ORI Struts, the Jeep handled like stock on the road and was better balanced than disconnected off-road.Hellwig Sway Bar….makes the Jeep handle almost like a car, but it is much stiffer off-road. For ~ $300 makes the biggest change of any mod I have ever put on a vehicle TBH. Just drove a curvy 500 mile trip through mountain highways, the change in cornering is crazy.
Correct. The longer Mopar lowers helped and would be a good first step if you don't plan to swap them out with adjustable LCAs.The 392 drifts more than other Jeeps I have run so I haven't checked the caster angle but if you are saying that longer lowers helped then you may have answered my question. Pushing the angle back a little probably helped a lot. A little toe in over spec on the tires helps as well. I always did a 1/8" to 1/4" with no affect on wear.
There isn’t really a front straight bar upgrade that will improve roll/sway. The big boy bars with long end-links actually increase tip in roll in corners on the streetDear, did you put the Hellwings rear bar part#7775?
Did you put any bars in the front?
Thanks
Jaime H
Mine is daily driver, local + highway combined. I have no complaints about the factory steering damper. Do you think Fox ATS with 18 clicks would be much better on-road handling?Yes! The passthrough design and the adjustability make it far superior to conventional steering stabilizers.
The last thing I'm trying to do is sell you on something you seem to be reluctant to purchase. So, if you have no complaints with your OE SS, then it's not broken for you, so save the $400.Mine is daily driver, local + highway combined. I have no complaints about the factory steering damper. Do you think Fox ATS with 18 clicks would be much better on-road handling?
I drive my wife’s Audi A4 too, tight and accurate steering. Jumping back to the Jeep steering I’m still fine.
Thanks for the feedback. I've been wanting to get the Fox ATS as an upgrade. Then the Fox 2.5 shocks to improve performance and comfort. I tend to do a few small mods each year so I don't break the bank and keep myself busy too.The last thing I'm trying to do is sell you on something you seem to be reluctant to purchase. So, if you have no complaints with your OE SS, then it's not broken for you, so save the $400.
However, given my all my Jeeps are or have been lifted with oversized tires and daily drivers, I notice a measurable difference. So much so, I even had a custom bracket fabbed for my '77 Bronco (lifted w/37s) and run the FOX ATS on it. The adjustability/versatility enables you to dial it in for any driving types/conditions including on-road.
Perhaps you can drive someone's Jeep with the FOX ATS SS. For me, I will never go back to conventional SS given my application of lifted Jeeps with oversized tires. On my 392 I have the Falcon Nexus SS which I like very much as well. But again, for you if it's not broken, then don't spend it.
From my 20 plus years in the offroad industry I would recommend a simple improvement.Mine is an all factory setup. The handling, especially at highway speeds can be a challenge. It is very loose and can drift a lot. I really don't go off-road. Looking for recommendations and best bang for the buck.
Hellwig rear track bar is another upgrade if mainly a daily driver.From my 20 plus years in the offroad industry I would recommend a simple improvement.
Tera Flex Falcon adjustable pass thru stabilizer or A Fox ATS pass thru adjustable steering stabilizer. You cannot go wrong with either one. I have a Falcon on medium setting on my wife’s Jeep and a Fox set at 15 on mine.
One other issue is 2020-2021 Jeep Wranglers that many do not know about is they have a recall in the steering box gear.
Another issue is add a degree of caster. Jeeps normally are about 4.0-4.5 degrees. Adding 1 degree makes a very noticeable improvement
I added the teraflex falcon adjustable, set to medium it’s mildly improved from stock. Set to firm, it alters the steering as if someone in the passenger seat has a hand on the wheel. It all but removes return to zero at slow speeds. in firm, it is tremendous going straight on the highway, but otherwise unusable for typical driving.Hellwig rear track bar is another upgrade if mainly a daily driver.
Have you put the new wheels and tires? If so which brand of tire?while scouring the forums, I ran across this old thread which just kinda stopped, but I thought I would add my issue and see if anyone has some feedback......
I have a 2023 20A which has the XR pkg, stock 315/70s and no modifications. It rides great and wander is reasonable for a live axle vehicle. After all it's a Jeep......
In prep for adding Fuel 20x12s with -44 offset and 35x12.50r20s. I decided to add a TeraFlex 1" leveling spacer up front just to insure I would not have a clearance issue. Also decided to add the AEV steering stabilizer which seemed like a good choice. the steering stabilizer was a bear to install. It's highly charged and is always trying to expand. took alot to compress it. the install went great. No issues. I was happy.
On the way home on the interstate I immediately noticed it was drifting/slightly pulling to the right. I immediately though it was the stabilizer. It took me 3 weeks to get back to work on it.
I swapped the factory stabilizer back and same issue.....slight, but definite drift right.
Yesterday I installed the MOPAR longer LCAs because i had the help to do it. that went fine, Trust me 190 ft lbs is alot of torque on the garage floor.....lol. Using the digital angle finder, it seems I maybe added 1 degree of caster. was disappointed in that small gain for that much work. of course it could be me not measuing correctly so I will be working on getting an accurate reading or just take it to an alignment place to get an accurate reading.
So......can anyone offer some experiences here? it worked fine until i took the front end apart to put in the leveling spacers. that should not have caused this issue. Also my steering wheel is in the correct straight ahead position..........and my steering angle (from off road pages) is zero.
Suggestions......
