Has anyone installed a hood lift support? Quadratec has one for the JL, but it's not compatible with the 392.
I installed the Redline Tuning Hood Lift Kit, a quality product that came with detailed instructions with pictures. It does require you to “notch” out a corner from the ECU bracket on the passenger side and remove a bushing on the driver’s side. I wasn’t comfortable with taking a grinder to the ECU bracket so I made two hack saw cuts and used a half round file to smooth out the cut...easy.Has anyone installed a hood lift support? Quadratec has one for the JL, but it's not compatible with the 392.
you have redline on 392? and didnt have to mod?I have Redline and I did not have to modify anything. If you read the instructions and then look carefully at the parts etc I think you will find that you dont have to do anything but plug and play.
CBH might have had something slightly different but I did not see anything that needed to be modified but I go very slow and carefully when I am trying to add something and not let it scream afterrmarket.
Very nice product, I normally use a different product but it wasnt strong enough for the 392's weight so I tried the Redline and will be going with them in the future on all my mods.
I remember that 100 plus degree day in Moab trying to lift my hood on my JK and then trying to put the rod in place to hold it screaming in pain from my hands burning. I wish I had discovered these before that day.
That's what I'm looking for! Thanks!What exactly are you referring to? Like redline tuning hood struts?
If so .. I dont even have my 392 yet (next Wednesday) but I used them on my 350R and they were great. They build a quality product.
And they do make some for the 392
Redline Tuning (21-20007-02) 2021+ Jeep Wrangler Rubicon 392 Hood QuickLIFT PLUS
Replace your hood's prop rod today with our Redline Tuning Hood QuickLIFT system. Progressive gas springs will lift and hold your hood without the need of a poorly placed prop-rod. Simply start to lift your hood and let our QuickLIFT system take over, lifting and holding firmly at the raised...www.redlinetuning.com
I don't like that we need to mod that.I installed the Redline Tuning Hood Lift Kit, a quality product that came with detailed instructions with pictures. It does require you to “notch” out a corner from the ECU bracket on the passenger side and remove a bushing on the driver’s side. I wasn’t comfortable with taking a grinder to the ECU bracket so I made two hack saw cuts and used a half round file to smooth out the cut...easy.
I also love the this mod and not a big issue cutting ecu bracket. Well worth the few minutes of modifications to make hood much easier to open and close. Great product and customer service from redline!I also installed the Redline product on my 392. I also had to do the listed mods to the ECU bracket. It takes 5 minutes to notch the bracket and apply some black paint on the cut edges.
Well worth the money, time and mods.
When I first installed the Hood Struts (before I did any cutting), I was able to close the hood on the passenger side only by forcing it to close; then I noticed the hood was slightly bowed out...not good. So I put some painter’s tape on the ECU Bracket, closed the hood again and found out what was happening...the strut was hitting the ECU Bracket, then sliding down toward the fender causing the hood to bow to the outside. So, I marked the area with red paint, cut out the notch with a hack saw, then smoothed it out with a half round file and finished with some touch up paint -- done!I have Redline and I did not have to modify anything. If you read the instructions and then look carefully at the parts etc I think you will find that you dont have to do anything but plug and play.
Now that’s the proper way to do it however , I just took my cut off tool and hacked a u shape out to accommodate for clearance. Wish I had your patience but none the less, mine clearsWhen I first installed the Hood Struts (before I did any cutting), I was able to close the hood on the passenger side only by forcing it to close; then I noticed the hood was slightly bowed out...not good. So I put some painter’s tape on the ECU Bracket, closed the hood again and found out what was happening...the strut was hitting the ECU Bracket, then sliding down toward the fender causing the hood to bow to the outside. So, I marked the area with red paint, cut out the notch with a hack saw, then smoothed it out with a half round file and finished with some touch up paint -- done! View attachment 2583
Hey, it works, right? Time to move on to the next project.Now that’s the proper way to do it however , I just took my cut off tool and hacked a u shape out to accommodate for clearance. Wish I had your patience but none the less, mine clears.
I think the ends of these shocks have quick disconnects, so they won't prevent anyone from opening the hood all the way to the windshield frame.Something else to think about is what your dealer does with your hood when they are in the engine compartment doing things like an oil change. I had a Jeep in one time for an oil change and I had went back to the service department and found that they had the hood resting on the windshield frame. No blanket, just metal against metal. Luckily I had PPF film on both parts otherwise I don’t know how it wouldn’t have scratched, especially since it was raised on a lift shaking as it was going up. It seems that these shocks would limit how much they are able to open the hood and prevent them from the temptation of putting this heavy hood on the windshield frame. At the end of the day the benefit of avoiding possible damage may outweigh cutting of the bracket.
I was apprehensive about taking a grinder to my ECU Bracket until I realized how small a piece I actually had to remove and I realized I could take my time with a hacksaw and a half round file. It was a fun project; much easier than I anticipated; and now I can lift the (26 lb.) hood with one finger just a few inches before the struts take over and lift it the rest of the way.The only way I would feel comfortable cutting my current ecu bracket is if I had a spare. Does anyone know the part number so I can order one?
