- Nov 16, 2022
- 1,532
- 3,012
- Current Rides
- 2023 Rubicon 392 20th Anniversary Edition, 1996 M1078 rolling fortress
- Thread starter
- #161
Spent some time under the Jeep replacing the long overdue shocks and adding inner fenders.
I chose the AAL inner fenders because they have an option to cutout for the Falcon shock reservoirs, but I think the rear set they sent does not have the cutouts as the controls are extremely hard to reach. The fronts are fine. I thought the quick turn fasteners would be handy for the odd occasion I'd like to get in there to work o the side of the engine, but they rattle on the trail.... ugh.
I might try to sandwich some weather stripping between the panels to quell the noise, or maybe just RTV the seams... or Velcro?
Here's a peek:
And the rear view:
While I had it apart, I took the time to install the new style tie rod form our friends at Doetsch Off-Road.
If anyone remembers my grumbling at my own laziness last summer, when the single-shear steering stabilizer mount broke on me 50 miles from the pavement on our way back from the Grand Canyon north rim in the middle of the Arizona strip. Our friends at Doetsch reached out and offered to swap for the newer style double shear setup using the factory stabilizer mount bracket, even though they did not have to, nor did I ask them to.
The problem was, I was I the middle of moving cross-country, and my shop was in shambles. Getting it put together fell far back on the list of more important items. They patiently waiting for me to get my crap in line, then sent me a new tie rod (the length was different due to the new custom ends) with the new style ends. I had to source a stabilizer mount as I could not find the one I removed (I swear it's here somewhere).
So a huge shout out to @jeepguru for taking care of me.
Here's a shot of the new versus old style ends. They are having the new ones custom made for this application, and were able to get it exactly the way they wanted. They are pure beef.
Thanks again @jeepguru !
Getting it put in was pretty straightforward, and getting the alignment dialed was interesting.
I bought a tool called "gyraline". It's a small, likely 3d printed sled, designed to hold your phone. It's accompanied by an app that uses the precision gyros in modern phones to pretty accurately ( the app says 0.01 degree accuracy is an option) mark the location of some flat spot on a wheel allowing you to check and adjust your own alignment specs., including toe, caster, camber and Ackerman angles. It was $160 bucks, and has already paid for itself.
Link: https://gyraline.com/products/the-case?variant=49331780583704
It only works for iPhones for now, but it's a bit of a game-changer for me.
Here's a peek:
And the rear view:
