Yes definitely needs to be removed and replacedFor those that have the 3 1/2" Metal Cloak game changer lift installed....are you using the stock drive shaft or going with aftermarket.... any clearance issues?
Great find, is this a new product?![]()
JL/JT: Factory Replacement CV Joint Kit – High-Angle Rzeppa
The TeraFlex JL/JT: Factory Replacement Rzeppa CV Joint Kit replaces a worn or damaged factory Rzeppa CV joint, without resorting to a high maintenance and expensive aftermarket U-joint style driveline conversion.teraflex.com
Not sure how new but it’s listed under new products on their website.Great find, is this a new product?
I think it went live this weekend. They had a YouTube video pop up on it this weekend. I was like well shit this is perfect!!!!Not sure how new but it’s listed under new products on their website.
They should prob update the description if that’s the case.
Anthony Nichols (Teraflex)
Oct 3, 2023, 12:35 MDT
Hey Troy, Thanks for reaching out. The JL/JT Rzeppa joint is a direct replacement. With our Rzeppa joint, You will NOT gain any more angle from our product like you would with our JK model.
It’s not a problem install your lift . You can drive your Jeep home measure for your driveshaft. Tom wood’s will have at your house in two to three days they will only build you a 1350. We have 63 jeeps on our club many of us are using Tom woods. There have been no issues with the. Tj’ jk’s jl Jlu and several 392’s .Aw man, just when I was getting excited. I've been digging for an answer for months and my 3.5" lift from Clayton is about to arrive so I gotta find a solution fast. It's either 1350 from Toms or Adams, or just keep it stock with mild wheeling. This sucks...
Best solution is to replace both. I have thus far only replaced the front and have done the Rubicon and a few other decent trails. It is on my wish list though.Do you guys think I can get away with just a front DS or should I get both front and rear?
I have not yet replaced my rear driveshaft ,MetalCloak said I should not need to replace it. A few guys have replaced there’s with Tom woods, it is in the back of my mind to do so. My buddy has a diesel he snapped his front 1310 u joint. Replaced with Tom Woods rear as well. Another friend went for 2 years with stock front but it failed on a run (v6 jk). Do the front budget for the rear. The front is easy to install yourself. Jeep just empty every pocket.Thanks @Earl 392 and @Cali392JL for the advice. Clayton basically said the same thing to me the other day. I can drive away with it and be fine on the road but to get a DS in the budget sooner rather than later. I was hoping Teraflex made a better replacement as posted in the couple of posts above but I talked with them today so as an added measure and confirmation for those seeking - Yes it is a direct level/feature replacement only; you're replacing a insufficient CV joint for another insufficient CV joint with the same (lacking) capability.
I have the Metalcloak front DS and run the factory rear shaft with no problems (Metalcloak 3.5" GC Lift). What sucks about the front CV shaft is that every oil change I have to remove some skip plates, remove the front DS to grease the CV joint. I would like to have a maintenance free front drive shaft. Hopefully Teraflex will make a high angle Rzeppa front replacement DS in the future.Thanks @Earl 392 and @Cali392JL for the advice. Clayton basically said the same thing to me the other day. I can drive away with it and be fine on the road but to get a DS in the budget sooner rather than later. I was hoping Teraflex made a better replacement as posted in the couple of posts above but I talked with them today so as an added measure and confirmation for those seeking - Yes it is a direct level/feature replacement only; you're replacing a insufficient CV joint for another insufficient CV joint with the same (lacking) capability.
