Exhaust button
Captain clap
New member
Cleveland
Jeep 392
Performance exhaust stopped working anybody have an ideas on what could have happened ?
i would bet there is an electric solenioid not working somewhere that directs vacuum to open the valves. I think if vacuum line was loose you would get big vacuum leak that would make engine run funny. Can't imagine both valves failing at same time. Electrical is my bet. Solenoid, wiring, fuse? Light working on button might argue against fuse.
Just my .02c
Have you ever checked the fuse box? I heard there could be lose connections. Not sure if the performance exhaust button wire can be found there or not.
I had an Apple Car Play disconnect issue, and wondered if it was the fuse box. There were plenty that were not in tight. That turned out not to help the Apple Car Play issue, and I have had no other issues to date, but the fuse box is super easy to check.
