Douno4Sure
- Feb 3, 2022
- 30
- 62
- Current Rides
- 2013 JLU Sahara Dune 2.5” Iift Fastback Softop, 2005 HD Road King
Got my 392 home last weekend. Went from Granger with 15 miles on the Odometer to Home 744 miles over 3 days following some version of the many Break-In recommendations. All is well and it's an amazing vehicle.
First major mod was to install APM Research Power Steps (Extreme). I've been my own mechanic and done many mods and complete rebuilds over the years, so this didn't seem too out of reach for me.
I disconnected the Negative lead to the Battery, followed the directions and improved on some of the wire-harness-routing recommendations. The system is isolated except: 1 Power lead to the Battery, 2 Ground leads and 4 Door Triggers that get spliced into tiny wires going into the BCM, Body Control Module. These are way up behind the Passenger kick-plate. You have to disconnect 3 major connectors, find the correct wires that carry the Door-Ajar signal, tap into them with the supplied Butt-Connectors, Reconnect these 3 major connectors and connect wires from the PowerStep Trigger Module to the PowerStep Harness, then Reconnect the Negative Battery lead and inserted the 2 Power Step fuses. All done and ready to test.
This is where everything goes wrong.
Open the door and various lights on the vehicle flash, dash lights up and goes dark, and steps do not deploy. (I also installed the Power Step override switch which I tried and the steps do go Up and Down with the override switch.
The problem is: the only thing on the Dash is the 'foot on brake push to start' message otherwise the dash is blank, none of the interior electronics respond to anything, the jeep does not start.... basically nothing.
What did I do to my wonderful new Jeep?
What do I do now?
What do I do now?
