Cryptostickers
mikeC
MA
2022 Jeep Rubicon 392 - Gobi
I uploaded my VIN to Cryptostickers and stupidly put in the the wrong date. I couldn't find anywhere to edit it and if I try to start a new one it says that VIN is already tracked. Couldn't find any contact info on their site. Any help?
It actually doesn’t matter. It will track none the less. If you put a date after your order it just makes other people jealous that you got yours sooner. :). But I wouldn’t worry about it, there is a lot of that being done intentionally.
This is absolutely correct. Cryptostickers will not tell you anything until the build sheet is published regardless of the date that was entered.
Thank you for the responses. :)
Hopefully you can find it based on name…. Just be sure to select All Orders before searching as the default is just with recent status changes. And the date is arbitrary. I used the date I entered it in Crypto versus the order date… never made a difference.
Thanks. I found mine under the wrong date - shows not found, not found. But looking at other Gobi orders (based on their user names), all show the same. Maybe they'll do them all at the same time.
I did the same thing. I think it might of sped things up a little
It will say “Not Found” until the build sheet is published. Could take a while.
I think a lot of us did that - there are 14 listed on Crypto with dates after the April 29 cutoff.
