psychoticmurse98
I just got my 24' 392 and am thinking about getting a K&N intake filter to replace the factory's. Is it worth it? I live out in the country so its very dusty and plan to take it to the mountains throughout the year. Thoughts?
DM'd!Go with S&B, hands down!! It's the only brand we install in every kind of truck & SUV. DM me for a deal with free shipping! Here it is in my 392.
I used to work in the filter division of AC Delco. Testing of air flow and measuring filtration efficiency of OEM air filters left me convinced of their superiority. A search of BITOG or other sources will show references to some third party professional lab comparative test data.
There are some small gains in flow with a K&N filter but there is a huge reason they do not publish their filtration efficiency. If its track day however, any flow improvement helps.
LF
See first response to your post. Stick with OEM for dusty environments.
It seems counterintuitive but while stock is super efficient next to the S&B from a "keep dirt out" perspective (your chart above), the other stat of airflow (below) shows the S&B allows more airflow into the engine vs OEM. And more air should also mean more power, though filter companies still don't publish those stats.Thanks for sharing the doc Dave. According to that PDF the OEM still filters better than the S&B; granted not order of magnitude:
I have no experience with the S&B, just with K&N (the cleanable, oiled version), which let in a lot of dust in. In addition to better filtration, the OEM is also much cheaper and easier to maintain. An improperly cleaned or oiled filter can lead to a lot less filtration. I also have very little trust in vendor tests - I'd rather trust an industry lab.
It would be interesting to see actual HP/Torque improvement that S&B provides as compared with the OEM. K&N always liked to post that, but alas, IMO at a major cost: dust filtration. That might be OK though for highway and track racing, but not dusty ones.
As a side note, even MOPAR's own CF filter (for the JK, not sure there is one for the JL) clearly stated that it was NOT to be used under dusty conditions. Unfortunately, that was printed on a notice that came with the filter (meaning I had to buy the filter to find out it was useless for my use case), and not on the product description.
