Carnut12
Getting polish/paint correction and a 9 year Ceramic Coating. Check out that reflection off the Paint.
Now that’s a shine!Getting polish/paint correction and a 9 year Ceramic Coating. Check out that reflection off the Paint.
Looks incredibleGetting polish/paint correction and a 9 year Ceramic Coating. Check out that reflection off the Paint.
You guys getting ceramic coatings….. make sure you get the annual top coat reinstalled every year to 18 months to keep the ceramic in good shape and maintain your warranty
We have seen 5 and 9 year coating have to be completely polished and reinstalled after a couple of year because it wasn’t maintained
The top coat is basically protection for your protection![]()
Do you have any thoughts/suggestions on the windshield protection film? I was thinking getting DYNOflex installed and local shop would charge $500 for the windshield.Lol
Yes…. Fire away
Been in the business since the 80’s
I do own a 392
I did PPF on the whole Jeep and ceramic coated it
PPF is no joke on the hood but the rest is 101
Thank you Mr. Tint for sharing your knowledge and suggestions!Both are great and all jeeps should have this. We all know how easy it is to catch a rock on jeeps and break the glass. The hard part is I can get replacement glass installed for $180-220 on jeeps so it’s a hard sale. With that said, I still think it’s worth while.
Clear Plex is made by Madico. Madico has been around FOREVER. Clear Plex was first to the market and proven to work. It’s a 4 mil polyester film (like window film) looks like the DIY kit is Pre shrunk for you (please confirm this)
DYNOflex is new to the market and is great at marketing. It is a 7 mil polyurethane (like PPF) being a polyurethane it make install quick and easy
Other then the thickness and material type……. Everything else is the same. Both 99% UV, optically clear, great warranties
My recommendations
If your handy and feel comfortable doing the install…. The clear Plex is a great choice.
should be really easy to install on a jeep. A lot like installing a large decal. You will need a spray bottle. Baby shampoo and a squeegee. I didn’t check but they should have a install kit to purchase. Just do the install indoors and have someone help you peel and place. The shampoo gives you slip. This allows you to position the film before you squeegee.
TIP: Make sure you clean the rubber and frame around the glass too. Film will want to slide down when positioning so this will help so you don’t pick up contamination (maybe I can do a install video for you guys) probably one on YouTube already
Use the DYNOflex if your not a DIY person or maybe source a local tint shop to instal the Clearplex kit to save some money. $500 is boarderline for a jeep only because you could replace it twice for that same $$ amount. If it was a Tesla or Porsche that is a $1500 to $3000 windshield then it’s cheap protection. Im not saying $500 is too much. I’m saying you will be paying $500 to protect a $200 windshield. BUT it is to protect OEM equotment
Hope that helps!!
I went down the youtube Xpel PPF and Ceramic Coating rabbit hole last night, and my main takeaway was that:Lol
Yes…. Fire away
I do own a 392
What's the cost on the annual top coat?You guys getting ceramic coatings….. make sure you get the annual top coat reinstalled every year to 18 months to keep the ceramic in good shape and maintain your warranty
Where are you located?I went down the youtube Xpel PPF and Ceramic Coating rabbit hole last night, and my main takeaway was that:
These were both very conflicting feelings for me.
- I really want to PPF and CC the whole damned jeep
- That it'll cost me up to 7-10k for this
I did also see that it's pretty common for people to do just high-impact areas (grille, hood, fenders, flares, a-pillar) and that this (at least somewhat) significantly reduces the cost.
I also found a jeep that had done a satin Xpel on the sarge green:
View attachment 3191 View attachment 3193
Really rad!
Yes. The Valor series does in the LlumarThe Stek and Lluminar films already have hydrophobic coating which eliminates the need for adding ceramic, correct?
Depends on where you are but I think $250-$350 is fair. It’s basically a carwash followed by a application or top coat of ceramic.What's the cost on the annual top coat?
