Cargo trunk size change?
Just curious if anyone else with a 2023 392 noticed the cargo trunk is significantly smaller than previous model years??
Ordered the Mopar liner but can’t use.
Running change maybe? My build was 9/23
BenLandry
Founding Member
Conroe, TX
Had to compensate for the giant garbage can muffler
Shortcut
Founding Member
Way Southern Arizona
2005 LJR; 2018 WKII TrackHawk & 2021 JLR392. "True Wrangler Unlimiteds Only Have 2 Doors"
The storage area pictured in your post appears to be the same size as my 2021 392. It's the muffler's fault. Also the center consoles are shallower than the none 392 JLs to accomdate the transmission and transfer.
OP
OP
SirMrD
SirMrD
New member
Parkland, Florida
2023 Jeep Rubicon 392XR
Thank you! That makes good sense. Yeaha...I bought the Console Vault too. Had to send back due to the smaller console....
c4ifford
north Georgia
Can confirm, had a diesel for 2 weeks before the 392.. the little cubby was much bigger.. and then almost non existent in the 392
Shortcut
Founding Member
Yup, the 392 rear storage compartments are much smaller to accomodate the muffler system underneath in the rear. Might want to check out the center console also, it is almost half the depth of a non-392 JL to acomodate the transfer and transmission.
Jeepstin392
Jeep 392 of the Month
Denver, CO
2017 Jeep GC SRT, 2021 Jeep Wrangler 392, 2021 BMW M340i XDrive, 2018 Mini Cooper S "7"
extra horsepower is contained in the space beneath the console and below the cargo cubby in the back.
Only on the XR. 😜
Shortcut
Founding Member
Hmmm....did not know that.
Yes sir, found that out when I ordered and received a Tuffy JL Console Security System for my 392 right after I received the Jeep in May 21, the assembly was to tall for the 392 console. Tuffy made it right though and sent me the appropriate parts to make it fit correctly at no charge. Problem is, the Tuffy console security system for the 392 is not big enough to accomodate a hand gun larger a small .380, even then it is a tight fit and not much room for anything else.
I think I wrote about this issue somewhere on this forum a year and a half ago or so when I originally encountered the problem.
2023 Wrangler 392 - $8,000 OFF MSRP! Granger Motors Just Bolt Ons.com StopwatchUSA.com Koons Jeep airRyd auto shipping MARK CDJR in Lake Charles Louisiana Metal Cloak Jeep Products
🔥 Popular Amazon Products 🔥
