No, the wires just join up wit the harness inside the tailgate and pass into the passenger side corner with the rest of them.Any idea where the power is coming from to power the air compressor?
You cannot see much, it's tucked in behind the spare tire mount. You can really only see the top of the cyl... I posted pics back when I got it here:
https://www.jeep392.com/threads/gurumans-20a-build.2632/post-43262
The compressor used by Mopar is similar with the single, not Twin ARB. The cost for that is around $230 (at NAPA according to google).
That's not to say that one is better than the other.
Did you still decide to get Mopars rear door Air Comp? I was looking at it also because it’s a factory setup. Then I found a nice one called Thor’s Lightning.Good point! I saw $338 at NAPA, but regardless, that total cost is still lower than Mopar’s! Also, based on Guruman’s photos of the compressor specs by Mopar, it looks like the ARB single outperforms it right off the bat at 0 PSI (see images below).
ARB 12V Single Motor Compressor CKMA12
Mopar Performance Swing Gate Mounted On Board Air Compressor (P/N 82216486AF )
Just for perspective below is the ARB Twin Motor Compressor CKMTA12 (Incredible performance!)
I still decided to get the Mopar version, I like the factory appearance and location more. There hasn't been any communication on a possible ETA though.Did you still decide to get Mopars rear door Air Comp? I was looking at it also because it’s a factory setup. Then I found a nice one called Thor’s Lightning.
I wish I had seen this thread sooner. One or two years ago I paid $500 cash for a new ARB twin at Jeep Beach.The ARB + Kraken setup cost slightly more than the Mopar option. I have not actually seen the Mopar's compressor nor performance but I do like the factory look and not having to take up space under the seats or engine bay. I've got one on preorder and will try share more details and the install when I get it.
Epic Kraken Kit - $315
ARB Twin Compressor - $592 (Lowest I've seen)
Total $907
Thank you for posting these pics! Curious: are you installing yourself or having the stealership do it?It's finally here! Here are some pictures of everything in the box
View attachment 34732View attachment 34733View attachment 34729View attachment 34731View attachment 34730View attachment 34734
No problem! I’ll be installing it my self and will try to document every step.Thank you for posting these pics! Curious: are you installing yourself or having the stealership do it?
That would be awesome! Thank you!!!No problem! I’ll be installing it my self and will try to document every step.
