Any body have an arb tire repair kit? Well you should. I have had mine since 2012 and needed to use it the other day because I picked up a 20 penny nail in the inner side wall rear tire..discount tire said it’s too close to the side wall to repair. this just happened to be my brand new spare that I just rotated in . So I pulled out the ARB kit . In the kit is a small black container with lube in it to help push the tool through and separate the steel belts. Then you insert the bacon strip. Well this lube was dry as a bone, but I was able to rejuvenate it with a bit of water . So check yours out . I now have that canister in a ziplock bag and I store the kit Flat so that it doesn’t possibly leak. The kit works great
