Hi Earl — good research, and you’re mostly on the right track. A few clarifications that may help.
First, a small terminology point: flow is current. There doesn’t need to be an external power source or “active electricity.” When you put two dissimilar metals in contact, you’ve already created a voltage (a difference in electrical potential) between them. Once an electrolyte is present (water with minerals, mud, road salt, etc.), that voltage drives electron flow — that electron flow is the current.
Think of it less like household wiring and more like a tiny battery that forms naturally. The metals themselves create the voltage; the electrolyte just completes the circuit.
Regarding coatings: powder coating on the skid and paint on the frame can significantly slow galvanic corrosion, but only as long as the coating remains intact. Any scratch, bolt hole, compressed area, or fastener that breaks through the coating can re-establish electrical contact and allow corrosion to start locally. That’s why isolation washers, gaskets, or non-conductive spacers are often used in marine and aerospace applications — they’re there to maintain electrical isolation even when coatings get damaged.
You’re also correct that in a steel–aluminum pairing, aluminum is the anodic material, so it corrodes preferentially while the steel is protected. That said, “less concern” is relative. Aluminum corrosion can still be an issue over time — especially around fasteners — and the corrosion products can swell, loosen bolts, and trap moisture, which can create secondary problems for the steel nearby.
So in short:
- Dissimilar metals create the voltage
- Electrolyte completes the circuit
- Electron flow (current) causes corrosion
- Coatings help, but aren’t a permanent guarantee
- Aluminum corrodes first, but that doesn’t mean the system is problem-free
None of this means aluminum skids are a bad idea — just that isolation and good installation practices matter if you want them to last long-term.
As another user pointed out, aluminum gets dinged up and becomes resistant to sliding. That’s what ARTEC makes their special surface material.
