392 Stock Wheels/Tires
dgerb
Nevada
While I'm waiting for my 392 and making a build list, I'm wondering what folks are doing with the stock wheels and tires they are replacing. Also, what are you getting for them?
I have seen reports of 1500 to 1800 by some but I'm now realizing the original 392 wheels will be a short run as the Recons use a different wheel and are now mandatory for a order so who knows what someone might pay for them. Not sure if I will or wont part with mine. If they were wider I would definitely keep them but I will probably go wider.
Saving all the stock gold trim in case I ever sell. Well unless I got an offer I couldn't refuse.
Mine will be for sale as soon as my new ones come in. I was thinking of saving them but can’t really justify keeping them in storage when I’ll never put them back on.
Is the Recon wheel wider?
Yes the original is 7.5 when mounted as it comes from the factory. If you buy the bead lock rings it essentially changes to 8" wide.
The Recon is 8" as mounted from the factory and probably 8.5 with the bead lock ring. Keep in mind these are bead lock capable not bead lock ready so to speak.
Yours actually look gold? Lucky mine look platinum. No gold.
