2021 Backup camera removal
GhostPepper392
O'Fallon, Missouri
2021 Jeep Wrangler 392, 2017 CTS-V, 2016 F150, 32' Sunsation
The rear housing is different for 2021. See pictures below, ensure your aftermarket carrier has addressed the 21' by providing a bracket/mount. I however do not have one so I will be working up a piece of abs plastic.
Remove tire carrier
Remove 2x T25 that go through the main tire carrier and camera housing and bolt to the wheel stud plate
Use flat head or socket and gentle tap on the holes (large and T25 holes) to release the camera housing
Remove T25 at the camera and use a very small flat head and gently pry to release the camera from the 4 tabs.
Remove tire carrier
If you’re using the Teraflex mount, they already have an adapter for your camera. Just call them.
Yeah I did, in the meanwhile I wanted to get it on since I have it apart
We just stuffed some paper towel in there until the part showed up. Lol.
Whatever works! Teraflex already replied to the request and is shipping the adapter.
