12v under passenger panel
Idaho392
Idaho
According to the manual, there are two stubbed 12v wires (battery and ACC) under the passenger instrument panel (pages 74-75). There is even a picture of it. I have found a single green wire that is stubbed, but have been unable to find the two mentioned in the book (red/white & pink/orange). Anyone else found them??
Watching. From what I have read there should be four wires that match the four aux switches as well as a constant power and ignition switch power.
The four wire bundle that goes with the four Aux switches are under the hood, next to the battery. I'm referring to the two wires that are supposed to be under the dash on the passenger side.
The owners manual......its a terrible thing to waste.
Finally found the 2 wires under the dash... someone decided to wrap the shit out of them with electrical tape, and have about 4ft of extra wire. LOL
Can you post pictures please? Thx
I found at least 5 maybe more but I had to take a break from unwrapping the tape also.
They were under the carpet at the meeting of the carpet and the firewall.
They are not near the instrument panel, I would describe them as under the carpet in front of the passengers toes.
Pics are South to North
Pic1 one is where passengers toes are and wires are in the bundle with the electrical tape
Pic2 is the bottom of the glove box which is removed when pic taken
Pic3 is the "Instrument Panel" where they claim the wires are
FYI AMP RESEARCH HAD THE 392 LISTED AND THEN REMOVED AND THEN ADDED AGAIN BUT DUE TO COVID NO INVENTORY. THE BRAIN OF THE AMP STEPS SHOULD BE INSTALLED INSIDE THE CAB NOT UNDER THE HOOD, THE ISSUE IS A HEAT ISSUE.
YOU CAN GET YOUR IGNITION POWER HERE AND TAP IN TO ALL YOUR DOORS BEHIND THE KICK PANEL JUST TO THE RIGHT OF THE LIGHT YOU SEE IN PIC 2
SO FAR ALL THE AMP XL'S WE LOCATED (INSTALLED) HERE HAVE NOT FAILED AND I AM IN SOFL SO THEY ARE BEING PUT TO THE HOTTEST HEAT TEST THEY CAN BE OTHER THAN MAYBE PARTS OF TEXAS OR NEW MEXICO OR UTAH AND SOME OF THOSE REMOTE AREas
